How to install front wheel bearings...
Old 01-17-2000, 09:25 PM
mattsibley's Avatar
I need some help fellas! How do I install my new bearings on the front of my 99 honda 300 4x4? Please let me know soon. I want to be able to ride again asap.
Matt Sibley
1999 Honda 300 4x4 Vampires, Lift Kit, 2500lb WARN winch
Old 01-18-2000, 11:04 AM
mattsibley's Avatar
Can someone help me?
Matt Sibley
Old 01-18-2000, 12:47 PM
TxDoc2's Avatar
Matt, you might want to get a Clymer repair manual. They seem to have detailed instructions and pics. I have never done the bearing job, though.
Old 01-18-2000, 06:26 PM
frankd's Avatar
its been a while since i changed mine ,its not very hard.remove the axle nut,the drum and i believe theres 4 bolts that hold the backing plate remove them and move the backing plate and brakes to the side i dont think i had to remove the brake line.remove the cotter pins and nuts from the ball joints take a hammer and give the control arms a whack where the ball joints go through DONT HIT THE BALL JOINTS this will loosen the spindle from the ball joints take out the spindle .theres a c-clip that holds the bearing in place i dont remember if its under the seal or outside of the seal but remove it drive the old bearing out and use the old bearing to drive the new bearing in be careful the bearing races dont come out when your driveing it in.use a new seal .i think that covers it,good luck.
Old 01-18-2000, 06:31 PM
frankd's Avatar
btw mine was a 95 im sure there the same if you have problems e-mail me
Old 01-18-2000, 08:33 PM
quad_300ex's Avatar
DO what Frankd said to do the tool that you probly dont have that you need is true-arch pliers because I change the bearing in my fourwheeler about 4-5 months ago.
Old 01-18-2000, 08:58 PM
200xtra's Avatar
my front wheel bearings went and i just bought new spindles for my 97 honda 300 4x4 its not much more expensive than honda bearings two spindles $112 for two.
Old 01-18-2000, 11:53 PM
mattsibley's Avatar
Thanks Frank!!! I'm printing that off right now, I plan on putting them in tom. I have some friends to help so I think between the 3 of us we'll get it done, I'll e-mail you if I run into problems.
Matt Sibley
Old 01-19-2000, 08:28 PM
Shane West's Avatar
Matt,
I've been away for a while....frank gave good instructions. The only other thing that I would do is pack the bearings with a good (Morey's or equivelant) quality WATERPROOF grease and put a bead of silicone between the backing plate. For some reason, the manufactures do not put very much grease into the bearings. Also, instead of putting cotter pins back into the axle nuts, use the removeable type of "hairpin" clips.
Good luck.
Shane
'97 Honda 300 4X - Vamped, Locked, & Lifted
Old 01-22-2000, 01:05 PM
mattsibley's Avatar
Ok, I have it all stripped down, when I gave the thing a whack the bearings simply came to pieces. The seal is being a pain in the butt to get off and I cant seem to get it. Also, oncle I removed the backing plate, the hole where the spindle goes in sticks our farther than the main metal pice behind it, From the view I have now, I can see the first seal and pieces of the bearings, also at the back of the piece I'm talking about I can see the other seal. How in the hell do i get to it??? Also Frank said something about a c-clip wheres that??? HELP ME ASAP!!! PLEASE!!!
Matt Sibley
Quick Reply: How to install front wheel bearings...
