kodiak 450 oil change
Old 04-28-2003, 11:44 PM
grizzllyking's Avatar
Default kodiak 450 oil change
Comming up on my first oil change on my 450 and i was wondering what would be the best oil to use....Do I have to use yamaha lube???? Is there another oil as good but cheeper?
Old 04-29-2003, 12:22 AM
Any one?????
Old 04-29-2003, 08:23 AM
Maddog75's Avatar
I use Chevron Delo 400 in my 450 and my wife's 400 Kodiak' $6.00 a gal. Oil Filters Fram PH6017a AC 2057 Purolator ML16817.
Maddog75
Old 04-29-2003, 11:53 AM
Coyotechaser's Avatar
It seems like anything with the letters "atv" on it is priced higher. If you have your manual it probably tells you to use the Yamaha lube or a equivalent. At least that is similar to what my Honda manual says but with a Honda GN4 oil. I use Valvoline 10w-40 rated (I think SF and/or SG) There are other main stream motor oil companies that offer atv oil. Just make sure that it is rated the same as the Yamaha lube. I buy my atv oil at a local auto parts store.
Old 04-30-2003, 06:53 PM
DezDude's Avatar
Maddog75,
I have searched high and low for the Fram oil filter that you mentioned. Where do you buys yours?
Old 04-30-2003, 08:51 PM
Maddog75's Avatar
Dez Dude I get Fram filters at Discount Auto Parts In Florida, check around if you can't find them I have a lot more numbers.
Maddog75
Old 04-30-2003, 08:56 PM
DezDude's Avatar
Thanks, I live in So. California and have checked Autozone, & Kragen with no luck. I will continue to check others.
Old 05-01-2003, 09:50 AM
ATVmadman's Avatar
i use yamalube
Old 05-02-2003, 10:58 PM
KodiakClyde's Avatar
I use Castrol Syntech 5w50 and Fram oil filter. I buy mine from WAL-MART.
03' Kodiak 450 4x4
Old 05-03-2003, 03:37 PM
Do a Fram atv oil filter search. I've seen them for a little over $5.00.
Quick Reply: kodiak 450 oil change
